- 228
- 58
- 28
- Chesapeake, VA
I will be painting my deuce with Behr paint soon. The bed and the cab have Carc on them. They will require minor sanding and priming in small areas. However I will have to sandblast my hard top. Also I have an unpainted NOS outer windshield frame that is raw steel. Once I sandblast and epoxy prime my bare components, what should be my next coating? Should I use some type of paint after the epoxy primer? Should I pick up just 1 gallon of Carc just for the bare metal parts? Then after the parts are painted apply the Behr? Keep in mind the whole truck isn’t getting blasted. Thanks for the suggestions.
