coolnick73
- 0
- 16
- Grand Meadow. MN
I had an ah-ha moment last night while trying to get to sleep. What if instead of a hydraulic pump or re-purposed power steering pump to push WMO through filters, why couldn't I fill a pressurized sandblaster with WMO and then use air pressure to send it through a series of filters.
I would have to replace the end hose with a hydraulic hose, but the only disadvantage I could see would be the moisture added into the air by the compressor. This wouldn't deal with any moisture that was in the oil prior to filtering (I know a centrifuge is the best). I have the sandblaster which is a cheapy from HF.
Here are some questions I have:
1. Does this idea make sense or am I nuts?
2. Can you use stock deuce oil filters left over from a spin-on oil filter conversion for pre-filters? If so, is there some sort of base that you could buy off the shelf that would fit them?
3. How small will the stock oil filters filter to and what is the recommended final filter (3 micron)?
