Sandblaster reccomendation
Chief_919
100
Western NC
I just picked up a nice military trailer mounted, diesel powered compressor. Specs say 15cfm at 175psi, but the same comepressor in civilian service is often sold as a 20cfm, so it may do better than 15.
Of course that means I need a sandblaster!
What do you guys like? I need to keep it $600 or less, hopefully less, as this is a hobby tool.
I have seen some now with a vacum in them that sucks the media back up and recycles it. Has anyone used them, and do they work worth a darn?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
No, those are based on siphon feed system. You want a pressure pot system. I got a Clemco and love it. Still needs a little work, but works great just the same.
CGarbee
530
Raleigh, NC
If you can hold off until you come to Raleigh, I'll show you both of my sandblasters and will tell you the pros and cons of each and why I invested the way I did... :)
One is a blast cabinet, the other is a pressure pot. Neither was very expensive...
My gas powered Ingersoll-Rand unit came surplus from a local contractor rental outfit, but is the same compressor head that is on a lot of military units. It is spec'ed at 15cfm at 125psi, but is 25cfm at 100psi... (I think, I'd really have to go look at the dataplate to be really sure). The lower the pressure, the more air it puts out...
If you don't have one yet, one of the Harbor Freight 1" extended anvil impact guns is a wonderful thing to have as well... Even better is the I-R unit, but they are way more expensive... :)
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Northern tool has nice quality ones reasonable (right around 5-600). Get the ones with a convex top so you don't have to use a funnel to fill.
Chief_919
100
Western NC
That sounds great. I won't be picking up the compressor until next week, so no hurry to buy the blaster yet.
Here are some pics of the compressor.
yd328
ct
I have a Brut blaster, it works great. I have tried some "inexpensive" ones only to have problems. With the Brut I just blast away.
Gary
