SBC Water Pump!
rolling18
75
Portland, OR
Just scored this Small block Chev Water pump for FREE!! new in box.
only thing is, I don't know exactly what vehicles its for the only marking on the box is
55-5077-11
After searching for how to make this into a WMO pump I cant find any that look like this to use as a guide.
Have any of you who have made WMO pumps out of these guide me in a direction to go with this? their are lots of "ports" and I don't know what is what
anyone recognize this and how to use it ? (yes im STILL searching for some tutorials or some refrences this particular pump)
thanks!!
Marc
rolling18
75
Portland, OR
yea thats what i thought too it's a 'NAPA"
and not quite sure how the liquid subposed to flow through this thing what ports to plug ect..
rolling18
75
Portland, OR
yea ill do that tomorrow but mainly I need to know if anyone has seen a pump like this for using in a WMO setup and how to do it.. (STILL searching:):shock:
rolling18
75
Portland, OR
DOOOH!!
glad it cost me nothing!!
maybe i can trade it for a OIL pump!!
thanks for the info, no wonder i'm having such a hard time finding info!!
is there a particular years/ makes that have the best suited OIL pump with little/ no modifications?
6x6TRex
Flint, MI
Give me the NAPA part # and I can check what it fits.
I might be wrong but I dont think there is any way to turn a auto water pump into a WMO pump. Your best bet is to get any V8 oil pump (preferably from a SBC) and use it instead, you will have way better results.
I built my own WMO pump for ~$30 using parts I had laying around. I used a 1/4 HP motor, SBF oil pump, and a Napa 1759 Filter on a modified base (no relief valve). It pumps somewhere between 5-10 GPM.
rolling18
75
Portland, OR
Might be for a big block. Never heard of them being used for pumping WMO.
You need a SBC OIL PUMP for WMO, not a water pump!
Water pump won't work as it will not self prime.
thanks for the Infoi!
here is the part # 55-5077- 11
maybey they will let me trade for THE CORRECT PUMP.. NOT LIKLEY HEH
rickf
1,425
Pemberton, N.J.
Water pump has to be part of a closed loop system to work and it is not designed to moved heavy fluids. The heater ports are only a small part of the overall system and will not work alone.
Rick
