Scored 3 Pioneer Tool Trailers
SoylentGreen
Hot Springs, AR.
Oh boy, another project. Picked up 3 Pioneer tool trailers.
#1 is in pretty good shape, will be restored as a keeper.
#2 a little rough but restorable or maybe a parts donor.
#3 someone got after it with a cutting torch and the floor is pretty rusty, definitely a parts donor.
All 3 have good chassis's. All made in 1975.
SoylentGreen
Hot Springs, AR.
:DHey TJ, you already have a really nice trailer, now it's my turn. At least you can pull yours behind your deuce. I would need a drop down hitch to pull one of these behind mine.
Actually just stumbled across them, wasn't even looking for one but the junk yard owner was talking about scrapping them or hauling them off to auction. I just had to rescue them!
ARYankee
33
Benton, AR
That's cool. You could pull it with the Dodge. Does the Ferret have a pintle? The good deals either come when you least expect it or don't have any money :) Great rescue!!!
harleyhouse
30
Oakmont, Pennsylvania
The pioneers are cool!
I always wanted one to make a camping trailer.
canvas and screen for the lift up sides.
a canvas room extension for the rear.
The Local search and rescue uses one. for field work.
Great Find!
SoylentGreen
Hot Springs, AR.
You're right Quickfarms, it will pull behind the deuce. I've only had these a couple days and didn't have time to check, it just looked like it wouldn't pull, at least not level anyway.
I'll have to flip the lunette like you said and put some 11.00's on to match the deuce and it should work fine. Thanks.
vtdeucedriver
Vermont
If your hinges are rotted, make a trip to your local TSC and pick up a section of impliment belt..............works great.
Storm 51
Just a Grunt
9
Seattle, WA
Does anyone have any drawings or pictures of what these trailers look like when they are restored (or were in use in the military)? What went in them? Is there even a list of equipment they carried?
DAP
Waxhaw, NC
Don't use belting it just rots and gives out again. Get an 8 foot stainless hinge from McMasterCarr for each side and use some squishy foam sealant for the crack so water can't get in. Works perfect.
vtdeucedriver
Vermont
belting 9 yrs and still going............. im good with it
