HQ-88
- 0
- 0
- Stillwater/MN
Hey all,
So, I have been getting the Scout all tuned up for a upcoming car show, and I keep running into the same problem. When the engine gets to operating temp, the clutch does not want to stop spinning. This problems only seems to happen when trying to go from neutral into gear. When the truck is cold, everything works just fine, but as she warms up, the problem starts. I have refilled the transmission fluid with a heaver weight gear oil that was recommended by a member here, but that did not seem to fix the problem. Also, I should mention that other than the clutch not wanting to stop spinning, everything works just fine, and the transmission seems to be fine as well. Its just the dang clutch.
The car show is on Wednesday, so I really hope we can figure this out by than.
Thanks.
Thanks.
