scratchy carc.
ken
25
Houston Texas
I picked some carc green from alpha-heaven. After painting some components i've noticed the carc scratches really easily. Am i doing something wrong? There are basicly no directions for appling it on the cans. I'm using rustolem primer . I think it's sticking to the primer well, it just seems like this coating would be more dourable. I'm spraying it with my touch up gun and it looks great. So far i've only painted small parts, running boards, jerrycan holder, and other parts i can fit in the sandblaster. But at $60 a gallon i don't want to waste it if there is something i can do to help it's dourability.
Dieselsmoke
CA/NV
Are you talking deep scratches or the light scratches left behind from something rubbing across it lightly? If it's the light scratches, CARC does that.
Jones
Sacramento, California
Ken,
Did you get a data sheet with the CARC? If you're paint job is fresh it'll be a little tender as it takes several days to a week to harden thoroughly, depending on conditions.
ken
25
Houston Texas
DS, If i rub it with my finger it leaves a mark. The first time i drive it throught the woods it's going to look like crap!
Jones, I didn't get any data with it. Only the label on the can. I painted these parts at the end of Sept.
Is there a hardner or a additive i can use to make it more dourable?
Jones
Ken, the sheet I got tells about the paint including the pressures for different spray rigs and the curing times. By upping the temperature it can be made to cure faster but as a one-part CARC it takes it's curing trigger from the moisture in the air. No hardeners that I know of will make it go any faster. I'll dig out the fact sheet and get a copy to you.
