Sealing Compound MIL-S-45180
Stranger
Weatherford, OK
I am rebuilding my injector pump and I keep seeing references to sealing compound MIL-S-45180.
I have tried searching the site and nothing pops of regarding it. If I google it there are lots of products that conform to MIL-S-45180D, but nothing specifically for its "non-D" sealing compound equivalent. Is this just standard liquid gasket making compound? Is it thinner that regular sealant? What have you used in the past?
There are some parts with REALLY tight tolerances asking for it. Specifically, I am supposed to put a thin layer of the sealing compound on the fuel supply pump housing cover before installing it on the fuel supply pump housing. "Apply a thin coat of sealer,MIL-S-45180, to housing cover and install cover (F)on housing. Secure cover with screws (H) and lockwashers(G). Tighten screws to a torque of 30-35inch -pounds."
If there was a thin coat of sealer between the cover and the housing it must have been microns thick, because there is NO trace of it now.
Welder1
156
Albany Ga
You may want to talk with a diesel injection shop and ask them what they use on similar applications. See if there is a Bosch authorized shop local.
Stranger
Weatherford, OK
After doing more research on MIL-S-45180 I found that it is co-listed with NSN 8030-00-656-1426. A search for NSN 8030-00-656-1426 revealed that it is none other than Permatex Aviation Form-A-Gasket No. 3.
I already assembled using Permatex Copper Spray-A-Gasket. Hopefully, it will work.
Jeepsinker
385
Dry Creek, Louisiana
When there is no gasket at all, the stuff that comes in a can with the little cotton ball brush is better. It sets up more like a gasket by itself than the spray. The spray is great for coating existing gaskets.
rustystud
2,725
Woodinville, Washington
This is the stuff. I have used this product for years now and it is great ! The only problem is it sticks to well ! If you have to remove the part it takes two strong men and a boy scout to remove it ! It is not a spray on gasket, you apply it with a brush.
Stranger
Weatherford, OK
I figured that out after I had already purchased the Copper Spray-a-gasket. What I did was spray it into a container and then use a small paintbrush to apply the liquid. Worked like a charm. If I had it to do over (which I really DON'T want to have to do) I would buy the stuff in a brushable form. HOWEVER, the brushable copper sealant intended for fuel parts isn't even listed on the Permatex website. All they have is the spray.
There are a bunch of "copper gasket sealers" available (e.g. Permatex Ultra Copper), but all of them say "not intended for parts in contact with gasoline". To my way of thinking, diesel is every bit as good a solvent as gasoline, so I wasn't going to take the chance.
Stranger
Weatherford, OK
My brushed on copper spray-a-gasket held to 60 psi. I'm satisfied and will not be taking it apart to apply the "correct" sealant. .
I used the spray gasket material to "rejuvenate" the gaskets as well.
