Search Feature
mangus580
284
Western NY
Guys, I have finally completed the 'rebuild' of the search index. You should find that searches are alot more useful now!
Try it out... Look up something you remember from the past, and see if it works. I know that recently, there has been mention of it being kind of useless, and I hope that is fixed now....
Junkyard Wars Crusher
12B20
Mike,
You deserve an official "Atta-Boy"!!! I tried a couple of searches for previous topics that I knew were there. It worked flawlessly. I use the search function regularly because most of the questions I come up with have already been answered.
For example, I recently did some work on the brakes on my 5-ton. By using the search function, I was able to find information about:
  • how to remove the vent line and the master cylinder cap
    how to lube the air pak
    Dot 3 vs. Dot 5
    Brakes that won't release are likely caused by a sticking air pak
    low air pressure warning buzzer
    bleeding sequence and techniques
I know its been said before, but this MV community is awesome! :D
Jeff
