Search Help
firefox
General
1,844
52
Berkeley CA
I need a little help understanding how to do an advanced search.
For example:
I know there is a post that contains the following information:
It is in the CUCV forum
it concerns flushing cooling system
The poster suggested using some pvc pipe
to divert the water from the upper radiator hose
so that it would divert water from the blast of the fan.
I believe he was feeding water into the radiator thru the fill port.
How would I formulate an advanced search?
Thanks for any pointers.
Bruce
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Did the thread start about flushing the coolant system? I'd search the cucv forum, and search "titles only" for "flush" or "flushing".
firefox
General
1,844
52
Berkeley CA
Thanks Gimp, but no luck so far. I tried several search terms but always end up with
hundreds of posts. I thought there might be some sort of way to combine search variables so
that it would search for the first and then search within the results for the next, etc.
Bruce
gimpyrobb
27,791
787
Cincy Ohio
I didn't see any threads in the cucv forum, that you posted in, that had to do with the coolant system.
Could it be in the cucv modifying forum?
glassk
Hampton, GA
http://www.steelsoldiers.com/showth...oolant-Drain&p=1239755&viewfull=1#post1239755
Hea wired, I have a simple trick for flushing coolant. Drain coolant. Take two 2in X 2ft lenths of PVC pipe, glue on a 90deg elbow. disconnect top rad hose from rad side, Attach the PVC to the hose with the open end pointing down. Fill radiator with water. Run the engine. The thermostat will open discharging the flush water. Slowly add water to the radiator as the thermostat opens and closes. Flush untill the water is clear. You can use a container placed on the discharge end to collect flush water and dispose of it. Unlike flush kits, which discharge water out the rad cap, this method keeps the engine dry by discharging water away from the fan.
firefox
General
1,844
52
Berkeley CA
Thank you very much glask and Gimp for your help! That was the exact post I was looking for
as I am sure you realized after seeing it. I still need to learn how to do these searches more
efficiently so I don't have to waste other peoples time.
Bruce
73m819
329
gainesville, ga.
"Location of Engine Coolant Drain?" as the thread title WILLNOT show up for a title search for CUCV cooling system flush/flushing. I have a HE11 of a time searching for a known subject, I try to remember (at my age that is tough) who posted in the thread, then search that member.
Another problem is that we have so MANY threads with CRAP titles that DO NOT go with the main subject of the thread which at times making searching by title for something almost impossible.
Using a extended search (cucv, radiator flushing), won't show up in the thread because it is a cucv thread, hence it will just talk about flushing the radiator.
SEARCH IS NOT MY BEST FRIEND
5,167
I was able to find what you were looking for just with the standard google search. 3rd result when I searched for "cucv flush PVC pipe".
Sometimes searching with less yields more.
gimpyrobb
27,791
787
Cincy Ohio
That would be searching with more. I only used one word searches, but I used the SS search, not Google.
5,167
*sigh* The vbulletin search sucks according to many, so I swapped in the google search to the main page. Now I'm getting people complaining about it. I can't win. rofl
1,193
And when you accept that fact and move on, you'll have a good day.
