Secondary Fuel Filter O-Ring
JDToumanian
14
Phelan, CA
I'm looking for the small square section o-rings that are under the bolt/washer that hold the secondary fuel filter canisters to the housing. They are not included with the (aftermarket) filters, and in all the threads discussing filter replacement I was surprised to find no mention of it. Mine are chewed up... I reused them last time, now they require replacement.
I bought a selection of o-rings from Napa, none are right. Either too big or too small. McMaster-Carr has square section o-rings but none of them seem to be quite right either. What are you guys using?
Regards,
Jon
cranetruck
75
Meadows of Dan, Virginia
Hmmm..I never had to replace mine...
If you have the MS number for it, you should be able to look up the spec.
Checked the ones on my spare engine and they are chewed up also.
jwaller
19
Columbia, SC
if cat doesnt have them I'd contact the dealers. mine were fine when I did my filters so I left the old ones in there.
JDToumanian
14
Phelan, CA
I see Saturn has original military filter kits listed... That may be the way to go if there isn't an easy source for the o-ring only.
Bjorn - That o-ring doesn't have an NSN number, only a part number - 10935481 which is part of filter kit 5702776. How would I look up the spec for the o-ring? I Googled the part numbers but didn't find specs. I don't have an ORD-9 book, if that's where the specs would be...
Jon
bottleworks
Central NC
IIRC, I believe the filters that Saturn sells are the NAPA filters. Apparently, Saturn sells the NAPA filters to the govt. So, the NAPA filters become "OEM".
