devilman96
- 17
- 0
- Boca Raton, FL
I am getting ready to do the plumbing on my Deuce's second tank and was debating the need for a vent line between the two tanks.
I am using a 24V external fuel pump which will be frame mounted and controlled by a toggle switch in the cab. One of the line taps in the top of the tank now has a SS drop tube for suction installed on it and the pump opening has a cover plate. The idea is to pump from the spare tank into the trucks main tank ether while driving or standing, the main is retaining its stock internal pump so no changes on that side.
Being that these are non vented tanks I think there would be a need for a vent line between the two in order to prevent vapor lock but it never hurts to ask what others are doing before hacking and whacking into something that may or may not need to be there
