Securing a HMMWV
rmgill
14
Decatur, Ga
So, in working on this friend's slantback, we've been discussing how to secure it.
Key Switch is in hand for install.
I've suggested he purchase a battery cut out switch.
We've discussed locking door latches.
That still leaves the slantback hatch and tailgate. What's the ways folks have secured that without their trucks looking like a poor bodge?
One thing we've also discussed is a weapons/tool locker set on either rear fender under the slantback, that way he can stow critical gear and have a second layer of protection for them.
Any suggestions?
Al Harvey
19
Dover, TN
Our's had steel cable that would loop around the steering wheel and just put a lock on it. Prevents the steering wheel from being turned. Someone could still start it and drive off but they will only go one direction.
gcbennet
Trenton, ON
Yup. The cable with an eyelet is built into the humvee around where the hand throttle is and will only pull out far enough to secure around the lower steering wheel with a padlock.
xmiltm998
winchester, ca
I use the cable around the steering wheel, installed a keyed battery disconnect, and have a brake pedal lock that's kind of like a "club." I also put a land mine under the drivers seat, you just have to make sure you remove it and don't sit on it
jwaller
19
Columbia, SC
Kascar sells key locks for the doors. Maybe they have something for the hatch. The upper hatch has a lock built into it from amg. Maybe you could rig a chain on the lower rear hatch latch.
rmgill
14
Decatur, Ga
Yep, I know about the key locks for the doors from Kascar.
Security of the vehicle is best accomplished by a key switch/battery lockout/steering wheel lock.
Security of it's contents when running around in the vehicle....that's tougher as the tailgate has ZERO security on it by default. Even if you lock the doors they can just open the tailgate.
dilvoy
25
San Francisco, Ca.
Come on man, haven't you thought of what old men have been using for years to keep "punks" from stealing their gas? Just get some hasps! Enough for all four doors, the top hatch and cargo hatch to tail gate area. Then for good measure get one for the fuel tank fill door that you will install. You can get keyed alike pad locks to make it easy on yourself. One look at your truck and anyone will think you are crazy and leave it alone. Job done!
rmgill
14
Decatur, Ga
I did specify that it should NOT look like a poor bodge. Padlock hasps would look like a poor bodge.
At this point I'm contemplating a pair of 24VDC Solenoid latches that can be thrown from the driver's area and which secure the tail gate and slant back. Have those throw a pair of catches that lock both the gate and the hatch at the same time.
zout
154
Columbus Georgia
Throw this at you - how about elec door solenoids - I would imagine there are remote types as well out in the realm of civy world you could work with. Google electric door lock solenoids and there dead bolt styles.
Al Harvey
19
Dover, TN
If you got the locks for the doors and the rear hatch, then couldn't you just use a slide pin lock on the tailgate. The slide pin lock I'm thinking of would be like one on a double door for a house. The pins that hold the second door locked. Or a hasp style mounted on the inside that you could just put a pin in it when the tailgate is closed. That way the tailgate is pinned from the inside and with the hatch locked it couldn't be opened from the outside. A clean installation wouldn't be too hard and it would not be seen from the outside at all. Not sure if my explanation makes sense or not, but I hope so.
rmgill
14
Decatur, Ga
The trick is getting something that is mechanically inside the vehicle and not on the tail gate, but accesible from some places other than climbing through from inside.
I suspect that some sprung cable type latches would also work and would be simple in that they could be manual or solenoid fired. What ever is put together should be simple and yet robust and solid. Water proof as well.
dohabandit
Tampa/FL
I put a key on mine, here is how...
Any suggestions?
I have 3 ways to secure mine:
1) I chock the wheel
2) I have a cable strap that pulls out and I put an American lock on the steering wheel
3) I took my KDS box and opened it up, drilled a hole on the side for a security/barrel style SPST switch. I then located the lead that energizes the KDS PCB box when the start/run lever is thrown and set the switch to interrupt this power. I noticed that the 3 wires that go into that paddle switch, the top one had a lot of WEAR on the rubber. Looked like someone had really been messing with it a lot. I talked to some friends in the military and they told me that they reach up there and just YANK out the lead to disable the vehicle. You could do that as well, so long as the person stealing it has no prior military experience, lol!
bikeman
501
Ft. Bragg, NC
Could you just slip a long (hasp?) style lock through the chain tie in points for the tailgate and the body point? wouldn't take care of the hatch, but would the tailgate.
samsays
great river ny
You could also use a mag lock I've used several of these for different projects...works well uses a 12 volt back up battery with trickle charger..
