SpoiledSpud
- 6
- 8
- Northern (ID/WI)
It does seem to work that way, thankfully.I talked to some customers that have bought cab tilt brackets without needing them. They have not used them. People buying them after they needed them have had to use them. It appears that the cab tilt brackets are repellent to tilting the cab!!! Get them so you never need them!
The brackets I bought from Speedwoble sat in my shop for almost a year but I finally broke down and tilted the cab to replace a chafed brake fluid line and some of the pneumatic plastic lines. If the weather stays mild, I will also properly install the HMMH front axle lockout system I got a while ago.It does seem to work that way, thankfully.
