SEE/FLU419 accessories
Speedwoble
298
New Holland, PA
I am in the process of making a few doo-dads for my FLU and thought I would open it up to more people. I already sell the Cab tilt brackets through Expedition imports. Below are three additional ideas I would like to make. Not yet offering for sale, just getting feedback.
A new power port/ Air buzzer bracket to allow mounting a 24V USB charger. Estimated $25 with the bracket and USB charger.
New Headlight mounts to allow mounting the LED headlight buckets at the current 5" headlight location. Estimated $200/pair(you provide LED headlights)
New Rubber gasket for the hydraulic handles through the back of the cab. 2 options here, either Thermoplastic Elastomer or Polyurethane. I have to complete the CAD model yet. Estimated $40 each.
Telescopic hoist mount on the FOPS to allow lifting the cab, or Retrieving the spare tire if it is mounted on the FOPS. Estimated $300.
Similar to, but more refined than this previous version I made:
Loader Skid Steer adapter. Estimated $800 before shipping.
Thoughts?
The FLU farm
1,256
The actual midwest, NM.
I think the cab gasket would be quite popular. At least I have yet to get my butt in gear and make something myself.
If it has built in rodent repellent, it'd be better yet.
Pinsandpitons
47
Central Washington
Agreed on the gasket. I would like to see the quick-attach also depending on the details. There are plenty of adapters out there that could be made to fit the FL-4 but a ready made unit would be worth $800+ to me depending....
peakbagger
359
northern nh
I have had some ideas for a retractable lifting hoist that attached to the drivers side ROPS upright for removing the tire and possibly the FOPS. The tire rig is easy but the moment arm for the FOPS means its got to be lot beefier. I expect I will just drive between two trees and rig up a crosspiece to lift the FOPS when I need to and then just leave it hanging it hanging.
alpine44
Asheville, NC - Elkton, MD
You can remove the FOPS canopy with the backhoe dipper as shown here.
Toolee
Washington
Gosh, yes--the cab gasket would be great!
I have thought it would be nice to have a hoist that could be used to help lift those dang heavy tools from the boxes and then swing them all the way around the rig to the hose reel. That would be useful!
Sgt Jiggins
Potato Peeler
204
Lynchburg, VA
I'd love to have the power port/buzzer bracket and cab gasket.
And perhaps the hoist mount.
I love my SEE but man is it proving to be one of my more expensive toys!
Sgt Jiggins
Potato Peeler
204
Lynchburg, VA
Received, and installed, today. In a word: impressive.
Good build quality, fit and finish. Thank You, Speedwoble.
Looking forward to more cool SEE accessories!
SJ/JD
Speedwoble
298
New Holland, PA
Getting a stainless steel hose for the cross-over air line from the regulator to the air tank made using the one from my parts truck as a template. Estimated cost of $150shipped w/in US. Who else would like one? The military has a service bulletin for this line as it rusts and contaminates the system with rust. Military recommends replacing the line with copper or stainless. The difficulty I have found is finding 10mm diameter line, so the local shop is making a custom 3/8" line with the compression fittings on the end.
{price edited 8-8-20}
