FLU419 in VT
- 3
- 3
- Vermont
Need some help trying to diagnose a complete brake failure a couple of weeks ago that I thought was a burst line or hose, but isn’t. I tried searching for a similar post, but couldn’t find one, so I apologize ahead of time if this was discussed elsewhere
Temps were cold, and had been for a while, and I think were approximately just a couple degrees above 0 F. Upon starting out, the brake pedal was very stiff, but it would still stop with a bit of additional effort on the pedal, sometimes stopping straight, sometimes pulling a bit to the side. After about half a mile, I had a normal brake pedal, and it didn’t pull, and stopped properly. Another mile into the drive, I started slowing down for a traffic light, and my foot went to the floor, and I had zero service brakes, but still had my emergency brake. Air pressure was good, and the alcohol tank was full, and turned on (I haven’t verified that anything was coming out though), and pumping the brakes did not give any pressure. There were no signs of brake fluid coming out anywhere, and there’s no visible rust on any of the lines that I could see. I didn’t have time to investigate, so I parked it, and went back today, 2 weeks later to figure out what the problem was. There were no signs of leaks, the brakes worked perfectly, and the fluid reservoir was full. I drove it around the lot, putting about a mile on it, using the brakes both soft and hard, and they performed as designed. Holding the pedal down , the brake indicator moved to 70(?) psi, and stayed there for as long as I held my foot down. Any idea what happened? Did I get an ice blockage in the air lines? If so, wouldn’t I still have some brakes, as doesn’t the air system just act as a booster, or would that cause a total failure like I experienced? I’ve driven a 419 that not only had air problems, but also had a hole in a brake line, and even though the pedal went to the floor, there was a very small spot close to the floor where it actually had brakes.
Temps today were in the mid to upper 30s, so there wasn’t any chance of ice in the air lines.
If it makes a difference, I purchased it at the end of December, and drove it from Northern NJ to Northern VT without issue. I’ve been slowly going through it and changing all of the fluids, but have not yet changed the brake and clutch fluids. It’s been driven about 700 miles since I purchased it, and has been essentially flawless, other than this “minor” issue.
Thanks for any insight!
