Set of M135 rims $?
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Looking at 6 M135 rims, with tires. What would be a fair price to offer? The tires may be good, but assuming they aren't. What is the difference in the offset compared to a M35 rim?
Dennis
rdixiemiller
Olive Branch Mississipi
The M135 wheel is setup to run as a single. You cannot run them as duals. I believe Bjorn (Cranetruck) has written that there is a 2" difference in the offset.
I see regular deuce wheels with fair/decent old tires for $15 to $25 each. If you are wanting to run 1100 singles, the M135 wheels are desireable.
I'd offer $20 each, depending on how they look. You can always up the ante if the seller does not want to take that price.
I am hoping to find a set around here for that price.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I am looking at them for running singles. This isn't a "must have right now" thing, but will buy them if I find them cheap enough. May end up getting a whole truck, they seem to go cheaper than 95 a rim! Going to at least 1100, or maybe the xl's.
wallew
If you don't mind 'stepping up' a little, call your local big rig yard and ask if they have an 6 lug bud wheels. They will be 9 x 22.5. I purchased eight of them, six on the ground with two spares. Prices start at $25 and can go up to around $75 each.
I gotta tell you that you will then be running big rig tires. They ain't cheap but you will ONLY purhcase them once. If you have any questions, contact me.
I am hoping to put mine on the truck in the next couple of hours. IF the weather holds.
If that happens, I WILL post pix.
jim
