sf-97 for M813A1 in California
drjconley
merced, ca
I just bought a M813A1 from GL and I need some help with the paperwork. The data plate has NL07Y7 C325-1007.
What year would that be from?
Would it be somewhat accurate if I listed it as a Jeep?
Is the vin NL07Y7 C325-1007?
What is GVWR and empty weight?
Thanks for all the help, I am haveing a blast with all this green stuff.
Jim
M62A2
M813A
MEP-003A
GL will put whtever you say on the paperwork. Just make sure your sf97 and any other documents you have match exactly. If I ever register a multifuel again....it will be a GAS multifuel....prior to 1975 of course.
PM me if you have other questions I might be able to answer.
hole
Alta Loma , Ca.
If I'm correctly remembering what I've been told, all diesel powered vehicals ( including off road construction equiptment ) with need to be retrofited so they wont " pollute" too much. At the moment, historical vehicals are/ will be exempt. WillWagner knows all the info and when, where, how much , etc.
Trailboss
138
Norwood LA
I believe that C325-1007 (is there a number missing?) is the manufacturer's vehicle ID number, and this should also be stamped on the frame behind the left front wheel. The frame number doesn't have the dash, so I would just use the number as C3251007 as the VIN.
