Pawnshop
- 21
- 38
- Austin/Cedar Park Texas
I just printed up my first SF-97 request form and the first page is easy, but I have no data plate on my Deuce so the info for the second page is going to be harder. I found the xxxx-xxxxx frame number so I assume that will do for the VIN#, the year and make are a bit harder to extrapolate, the xx25-xxxxx tells me that it is in fact a M35A2 so I have that part and I guess the common published data will work for empty/gross weight. I have numbers painted on the door plate but they may not be correct (I suspect this vehicle had the numbers swapped by the motorpool to keep it from DRMO at some point in it's life), does that number need to be included in the VIN#? ALSO, if in fact the dataplate was "lost" and the door numbers swapped what then? With no numbers visible, I was definately the first to lay eyes on that frame number in a LONG time (decades of undisturbed gunk on it), if this vehicle was written off long ago will I even be able to get a SF-97 on her? HELP!!
My door number is:4D5970
Frame #:0325 30313
thanks in advance,
Sam
Frame #:0325 30313
thanks in advance,
Sam
