sf97 - deuce
ctmustang
Thomasville-N.C.
I am going to submit my 97 tonite and was wandering so I only have to do it 1 time what are you fellas putting for the weight and then the GVWR on a deuce?
Thanks CT
DieselBob
13
Arnold Maryland
From TM 43-0001-31
Nomenclature: TRUCK, CARGO: 2 1/2 Ton, 6x6
Weight: 13,700 lb
Payload: 10,350 lb, Off Road: 7,000 lb
The GVWR would be 13700 lb + 10350 lb = 24050 lb
SCSG-G4
PSVB 3003
3,317
Lexington, South Carolina
I used that on my first deuce, after that I have used the expected max cargo weight in my use, which is far less (only about 3 or 4 thousand pounds). I also tell the clerks it will be empty most of the time (which is true). Makes about $90 a year difference on the price of the tags. YMMV
