Shackle Pin Grease Problem
coyotegray
10
Oklahoma City
I have a 101a2 that is in very good condition I have been working on.
I have replaced all the grease fittings but still have two that are clogged that I cannot grease. Both of the rear/top pins will not take grease.
Anyone have a trick to open them up without removing the pins..?
Thanks,
Andy..
Wolf.Dose
9
Boehl-Iggelheim, Germany
There is a change, which sometimes helps: Lift the cassis that the axle is hanging free. Then try to apply greese. If this does not help, remove the fitting and get all the old grease out. Also remove the hanger and get the old greese out of the greesing hole. Than it will work. At least at my trailer that helped.
Wolf
m16ty
211
Dickson,TN
Here's what I did one time. I had an old small hyd cylinder. I took the cylinder and packed one side of the piston full of grease. Then I hooked the other side up to my porta power. Hooked the other end (with the grease) to the fitting. Pump it up and I've yet to see a joint that won't take the grease. I can go up to 10,000psi with this setup. You'll need to remove the fitting and screw the grease hose directly into the joint. I've also blown a few hoses using it.
I heard people having good results with the cleaner mentioned above also but haven't tried one myself.
rosco
Delta Junction, Alaska
If Wolf's trick doesn't work, pull the zerk and run a small drill in it. If that still doesn't do it, pull the pin and clean it. If grease was regularly applied, the stuff wouldn't get hard.
housemover
charleston W.V.
Heat will also work. But you have to remove the zerk or it will ruin the spring inside of it. If you use the heat method be careful not catch anything on fire.
