Shackle Working Load Limit
donalloy1
Martinez Ca
Gents, does anyone know the Working Load Limits for Shackles and the Frame Rails they reside upon? Do not see the WLL casting marks I normally see on Shackles?
Reason for asking is simple. Can I safely Jack vehicle corners up with Hi-Lift Jack off Shackles? Quick Tire changes in field is main idea.
Tried when I got home today with new Jack. Seemed to work very well. Might be asking a bit much of vehicle engineering though.
Input is greatly appreciated as usual. DMLII sends...
ODdave
40
lansing michigan
They will hold, Better have a HE!! of a tall jack, By the time the frame flexes out and the suspention is at full droop your gonna be to tired to change the tire2cents
KsM715
142
St George Ks
Thats why you always carry a short piece of chain when you use a hi-lift. (chain the axle to the frame to prevent the axle from drooping).
The CUCV transportability TM says you can lift the truck with themso I think its safe to say you can use them as a jacking point.
Keith_J
1,323
Schertz TX
The spread of cosmetic off-road features contributed to this question.
While the frame extensions are square tubes, the shackles are up to the task. Same pin diameter as 2-1/2 ton series, probably because of the tubular extensions. This gives greater bearing area with the reduction from tubular steel.:idea:
donalloy1
Martinez Ca
All good information Gents. Thanks for support as always. Yes it is a Heck of a High Hi-Lift Jack. Was about half way up full travel when KM2 35 came off ground. I am good to go. Now just to figure out where to mount in vehicle? DMLII sends...:driver:
2002ford
dayton,oh
We used them at FT. Campbell for slingloading under choppers. You can sling load single or in pairs side by side. The Hummer we used the ones that come up through the hood. A jack wont hurt them but if you put a single chain through both front or rears and pull real hard they will bend in towards each other. Dont ask how I know. Lol.
