poppop
- 39
- 48
- Brooklet, Ga
I posted the questions about the injection pump on my dump truck earlier. Today I got it running and it runs great. I knew the guy I got it from said the one time he started it that it ran wide open and he shut it down with the shut off cable. When I tried to crank it there was no fuel. So what if the fuel did no turn back on when the cable was pushed back in. Removed the plate with the shut off rod today and yes it is stuck. This shaft is aparrently the control shaft for the rack. When I moved it back it started right up. I sprayed PB blaster on the shaft and kept it running by controling it with my fingers. when the engine got hot and with repeatedly working the shaft by hand it freed up and now works great She purrs like a kitten. Now to figure out why the brakes don't work. Thanks for the replies to my earlier questions.
