Shear pins for the winch
dc3coyote
19
Chattanooga TN
kinda, but a grade 3 bolt shears first. I have used it for years with my tractor. an older Massey Ferguson
and no I dont use it much at all
dc3coyote
19
Chattanooga TN
I dont have the specs on this computer but if I was stranded I would not think twice
to use one, the man I talked to at the Tractor shop said they were the same
rosco
30
Delta Junction, Alaska
If your doing winch work, you need extra shear pins. The forward/reversing of the winch, under normal loads, will cause the pin to fatigue & shear. BUT, if your shearing good fresh pins, your in an overload situation. The winch should do all the work you need done, at not much more then an idle on the engine. If you speed the engine, it should only be to increase the line speed. If you need more power, put two parts in your line with a snatch block - something is surely going to move then.
Lee in Alaska
bottleworks
Central NC
Saturn may still have some...They were $3.50 each.
The key is to determine what alloy they are. I am thinking 2011-T3 would do fine... Any thoughts?
cranetruck
75
Meadows of Dan, Virginia
I did post the alloy some time ago, but "search" doesn't help me here. I had found the alloy except for the temper (T3, T4 etc)....
Found this after a lot of searching:
http://steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=16075&highlight=
...... the alloy for the 260 series 5-ton winch (5315-00-209-7979), it is the 2017, probably -T4 temper, which has a shear strength of 38,000 psi.
It's a start...
wiggall
151
Lenore, Id.
According to TM 9-2320-361-10 the Shearpin for the 5 ton front mounted winch is ALUMINUM. FTG2 Wiggles USS EDSON DD 946 1968-1973
Blood_of_Tyrants
11
Lebanon, TN
Yes, we know that. It is the type of aluminum that we need. Different alloys have different strengths.
