Shelter Lifter
59apache
Chipmaker
1,299
29
Bavaria / Germany
59apache
Chipmaker
1,299
29
Bavaria / Germany
You can see the holes in the long tube and the winchbase, they have different distances, so i have a 2" raster to equalize uneven ground.
What you can not see was the frustrating part of the story. My first idea was to use a Hilift in the middle of the narrow side of the shelter. That doesn't work. You can lift it with ease, but in the same moment the hole shelter moves to the side. Its like saw off a leg from a 3-leg stool.
Many curses later, i had the idea with the winches. It's cheap, it's simple, it's lightweight. I've thought about hydraulic cylinders like the cylinders on a motor lift. To heavy, to expensive, to short stroke.
It works...2 persons, max 10 minutes to lift the shelter on the truck.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Just so you know, Matt has put 4 of the small Harbor Freight winches on his set-up. One at each corner with a bank of 4 switches. Much easier to raise and lower. Maybe a consideration for the future.
59apache
Chipmaker
1,299
29
Bavaria / Germany
didn't know that, in his thread he had used 4 hydraulic cylinders. I had thougt about that , but i've decided for the manual winch. works everythere, everytime at every temperature.
gimpyrobb
27,786
755
Cincy Ohio
Uh, thats sweet and all, but why is it so much longer than a 280? Is it going to be used in that deuce or a 5ton?
59apache
Chipmaker
1,299
29
Bavaria / Germany
it's a belgian shelter. It's for this deuce. Weight is about 1,5 ton , the whole truck ~16600 lbs. Weight distribution is also ok. For my use it's ok. Most time i use it as a normal truck.
swbradley1
Modertator
1,705
Dayton, OH
Good job. I was wondering where that extra size came from on an S280...
Matt's new setup is pretty cool. Runs it all from a pendant so he can adjust level while walking around the box and it all runs off one 12v car battery.
No.2Diesel
11
Huntington, NY
Wunderbar! [thumbzup]
Excellent fabrication skills, looks great and I like the large outrigger pads with ball swivels for uneven and soft/wet ground. Thanks for that Haacon link. Did you have the lifting legs galvanized? Post some pics here next time you lift it in the yard or out in the field.
