Shelter S-280 part, does an S-530 have the same.
buffalocody
Powhatan, VA
With thanks to all those who have corresponded with me on this problem.
I have the S-280 shelter and need the brackets to mount the M-720 dolly to the 280. Before the moderator reminds me to post in the Wanted section, and I will, the question came up if the S-530 shelter has the same brackets.
The 280 comes with 4 brackets, 2 each end, that are mounted to the sill. These look alot like large cast drawer pulls to a piece of furniture. The 280 has holes drilled in the sill for mounting. The M 720 Dolly/Mobilizer has lift arms that attach up into these brackets for lifting. The 720 also has arms that attach to the corner rails. I obviously need the 4 brackets to put the 2 units together and move the things as a unit. Great hunting cabin is the plan.
The question I have, did the S-530 have the same brackets and possibly have a different part number. I need part number SC-D-595002-2. Geicher is not an answer to the problem with a cost of over $500 per.
Seems I have an S-280 that was manufactured after the M 720 was stoped for production and that is why it never had any installed. I have contemplated making my own, but these are trick cast pieces and make the package look original. Any ideas, leads or help is appreciated.
NEIOWA
127
NE IOWA
Many S-280 have no bottom foot/brackets. I'm also looking for some. Anyone have idea of the NSN? Not finding in the S280 or M720 TM.
