firebuilder06
- 0
- 1
- Pawnee OK
Check trans light is on, shift controller showing -\-, no start.
Issue happened just recently after having a check trans light and only have up to 5th gear. Ended up having no gears one day. Dug into WTEC3 diagnostic troubleshooting manual to find bad ECU. Replaced had no issues. Drove it a few times with no problems. Last time to drive it heading home the check trans light came on and only could go 40mph after a stop sign. Been digging to see if there is a short somewhere or if new ECU is bad. Troubleshooting manual shows -/- instead of -\- on selector switch. Any ideas?
