shifting and grinding gears
KC4MNE
FtLauderdale, Florida
1953 M37
When shifting from 2 to 3 I have to be EXTREMELY gentle pulling out of 2nd gear or I grind 1st on the way to 3rd.
Are ALL M37 this way or is there something wrong with the shift mechanisim / detents in mt tranny.
Manny
CGarbee
552
Raleigh, NC
You're transmission needs some TLC. You should not be grinding anything.
Check the slop in the ball at the top of the tower (where the shift lever is attached) as well as slop in the shift rails first.
ABLinn has the complete rebuild kits for the first series transmissions as well as NOS shift towers (easier to replace then rebuild if this slop in these components is the problem).
Poke aroudn a bit, let us know what you find, and we'll help you get it back into shape.
Good luck.
