shifting issues
levisaacs
waco/ky
Hi guys i have a 66 2 1/2 duce. i just had a air shift case installed and replaced the sprag that didn't work. i also installed a original pto winch on it which included installing the pto on the side of the transmission. Everything works great but now the truck dont shift down without grinding really bad!! i cant seem to figure it out, the pto is not engaged i checked thats what people said to check. ive been working on this for 2 months with no luck! any suggestions....
1,128
1. Is the trans full of fluid?
2. Is the PTO properly shimmed?
1,128
So what was it? Ever figure it out?
Ford Mechanic
Edenton, NC
smart a$$... :patracy:
I thought it was one of those things like a muffler bearing.... no such thing. Guess I got edgucated today;)
Mike out for the weekend!!!!! We're going to the RODEO!!!!:jumpin:
Floridianson
2,501
Interlachen Fl.
If the Snycros are good then yes you are to tight on the gear. I use one thick gasket and one thin shim gasket and never had a problem being to tight.
levisaacs
waco/ky
Sorry guys for not getting back sooner. First of all yes to everthing said, we shimmed the case and it did not help, so we shimmed it again and it has made a big difference. ITs not as smooth as before all the modifications but manageable! thanks for all the help!
Floridianson
2,501
Interlachen Fl.
If I rember NAPA only offered two different sizes. There would be to many gaskets if that were the case so like I said there is a thicker one and a thin one. I don't know the thousands.
