Shifting Transmission
Loose Deuce
South MS.
How smooth is it supposed to be when you shift the transmission ? Mine is sorta stiff but doesn't grind any gears if you can hit the right slot. My stiffest place is when I try and put the shifter in second gear, the slot just to the right of reverse.
Seems to be easier when going to second from first though. but going to second when not moving is pretty stiff but managable. Just was wondering what it is supposed to be like.
OPCOM
27
Dallas, Texas
If you are not moving, the gears won't spin and engage easily. With the transmission in neutral, how hard is it if you let off the clutch for an instant to spin things up in neutral -then back on the clutch, and then try to put it in second while the gears are still spinning? It should slip right in, especially of the transmission lube if cool.
