Shock Change Gurus, Help!
dabtl
Denton, Texas
OK, I got the civilian 66903 shocks. I cut the bushings in half.
There are eight metal cups to hold the bushings on the original shock and only four on the replacement.
Do I use only the four for the new shocks or use the old metal cups to fill out the assembly? Does the new bushing ride on the mount as opposed to a cup?
Enquiring minds want to know.
m-35tom
222
eldersburg maryland
the bushings go right against the frame and axle mounts, 4 metal washers on each shock. monroe 34787 are a perfect fit for replacement.
dabtl
Denton, Texas
m-35tom
222
eldersburg maryland
RE: Re: RE: Shock Change Gurus, Help!
i did not mean you used everything that came with the monroe shock, just that the rubber bushings go right against the mount with a metal cup only on the shochk side.
acetomatoco
Guess I am confused re the OEM comment... my advice was to use the Original Equipment Manufacturer (OEM) mounting method... And I fail to see how a method could become dated...you put the new ones on the way the old ones came off.. Good thing we're not discussing anything more complicated like washing the windshield.
dabtl
Denton, Texas
I found that I could use the stock bushings, without cutting them in half, to install the shocks. No matter, OEM or not, they will be much better than the rags I had!
dabtl
Denton, Texas
Got them done this morning.
Removing the old shocks was quite easy. They were completely shot. One had some resistance and the other had none.
The 66903 shocks went right on, after chasing the threads on one, using the parts supplied. I did not need to cut the bushings, it appears. We shall see.
