Shock replacement, M923A1 driver's seat
CES 3245th
Boston Ma
I’m hoping somebody out there can give me and easy way of removing and replacing the shock underneath the front drivers seat of my M923A1. I just want to work Smarter Not Harder!! Remember now, it’s just a question!!
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Replace the seat with an air ride one. You back, butt, and mind will appreciate it. A $200 investment for a use air ride seat, pressure protection valve, and regulator. Check a local truck junk yard.
The spring seats suck. Period. A shock replacement doesnt help at all.
Sent from my SM-G935P using Tapatalk
kneesnthebreeze
jefferson, ga
I realize you posted this a while ago, but there is absolutely no easy way to do the shock replacement. The "easiest" way is to unbolt the chair as it is attached to the floor pan and start going at it from the underside- once its outside of the vehicle. Took me all day to do mine and decided that if the shock ever wore out again i would just take some old rubber cut up and crammed under there. The seats do actually ride nice with a new shock but im not sure the sweat and broken bolts is worth it.
CES 3245th
Boston Ma
You're absolutely right there is no good way doing this and I did end up taking the whole seat out of the vehicle much easier to replace the shock.
