therooster2001
- 43
- 28
- Colorado
Well, I bought (2) 12340070 and was buying (2) 12340071, but the shipper sent me (2) 12340072 instead. I've seen people recommend (4) 0070 and then others recommend (4) 0072. Now my question is, do I have a crappy combination? There are not great specs on the 0072, and they look identical to each other, but I am sure the lb rating is different. I read 0072 are for the heavies. My little 998 is not going to see a ton of loads. Should I go for (2) 0070 on the front and (2) 0072 on the rear or should I return something and go for the same all around?
Edits:
It appears I have (2) 0072's on the back, and (2) 0071's on the front currently.
Are the 0070's ok for the front as replacements?
And the big 1-7/16's nut seems to not want to handle that size socket and wants a 1-1/2 with a bit of slop. I also can't seem to get the socket on the rears unless i bend the bed up a bit. I didn't jack the truck up yet, but since it bolts to the frame, I wouldn't think this would move. Anyone else?
Edits:
