Short airpack rebuild, looking for replacement canister
Johny5
Altamonte, FL
Hey guys,
I'm in the process of redoing the breaks in my M35A2. I tore done the short airpack in hopes of rebuilding it to find out there was some serious pitting on the canister. I am wondering if anyone has this part they would be willing to sell me. I don't need the full airpack as everything else is in good shape, as far as I can tell so far.
rustystud
3,323
Woodinville, Washington
Hey guys,
View attachment 674778View attachment 674780
Well that's the problem. Pitting in the canisters is the number one problem with all the air-packs ! So everyone who has bad canisters is also out there looking for them. I personally went through seven "long style" air-packs to find just one that had a good canister ! There is a special oil that is supposed to be used in the air chamber that lubricates the seal and also prevents rust from developing, but no one uses it. I never bought any as it is only sold in 5 gallon buckets and costs over $500.00 . A few years ago I invited any local Steel Soldiers members to go in on buying a bucket but I got no takers. So I have been using "Silicone Grease" and it seems to work OK.
The "long and short" of it is you will have to buy a complete air-pack from someone unless you get real lucky.
Floridianson
2,521
Interlachen Fl.
I will look for one and if so you can have it. Yea Rusty like you adding an air dryer the Deuce should have had one from the start.
USMC 00-08
214
Skiatook, OK
Would air tool oil work in there instead of the expensive oil? Has rust inhibitors etc.
1,147
I've never opened an airpack that had what I would consider a good canister.
rustystud
3,323
ANy chance of sleeving it?
I looked into that a few years ago. The cost was over $300.00 . For a little more money you could buy an NOS unit. I tried to find a place that could just fab up a stainless steel unit. Again the cost was way to much. I found the silicone grease works well. It stays in place and doesn't drip out and it leaves a small film of grease on the canister walls to prevent rust. It's not that "special oil/grease" the military recommends but it is a whole lot cheaper, and along with the "Bendix" air-dryer I installed it should last pretty good.
