Shortening a M923 bed
461
Sandyston, NJ
I am going to be putting a knuckle boom crane between the cab and bed of a M923 soon. I was wondering how much shorter in legth is a M35 bed than a M923? My thinking is to shorten it down to the same size and be able to use a stock cargo cover for a M35 on the M923. Also are the height of the M35 and the M923 covers the same?
1,808
5 ton bed= 14' 5 ton ISO bed = 15' Deuce bed = 12'
5 ton bed has 5 bows and the deuce 4. Chopping the 5 ton bed will throw off bow spacing. Probably be easier and not that much more money to sell the 5 ton bed and buy a deuce bed.
Sandyston, NJ
How can you tell if it is an ISO bed?
Not Worried about the bow Spacing. I plan to build a custom frame that will be removable from the bed to support the top. There will be a lifting eye in the middle and i will be able to remove the entire cargo cover and frame with the crane. Should make it much easier for unloading cargo from the bed.
1,808
ISO beds have 4 removable sides and a tray in the back to store them in. Should also have tie down points for ISO containers.
caliber1
Elcho, Wisconsin
Hey Kenny, the deuce bed does have 5 bows. Well, mine does anyways.
