Milkman357
- 15
- 18
- Des Moines, IA
Ok My M-1009 has a shudder...
I took into the transmission shop, because I thought it was my second gear in the transmission.. but he says he thinks it engine related.
Researching this sight, I need to start off changing the harmonic balancer..
It's not the tires, they are ok, That was the first thing I checked..
Both driveshafts have been rebuilt/balanced..
When I first start off, engine cold, it doesn't shudder. After a few minutes I will get a vibration after 2nd gear shifts... under acceleration. The Transmission guy thought (knows nothing about diesels) first gear doesn't put much of a load on the engine, but second gear actually makes the engine work.. and that might be a cause.
I've ordered some rebuilt injectors, so I'll change them soon.... If the harmonic balancer and injectors arnt the culprits.. Would an injector pump going bad cause this? 99,000 miles, probably original IP.
My dash kinda vibrates on the passenger side.. I think the vibration is coming from the passenger side btw... It feels like passenger front is where the vibration is coming from.
I have a crate engine laying around from a HMMV.. But I think it's bad. I could use that injector pump as is.. or send it in as the core... I'm going to need an IP someday.. just a matter of time. Kinda sounds like I'm talking out loud, I am..
Just curious about other people's 2 cents....
Would an injector pump going bad, cause one side of engine to vibrate?
I see no gray or excessive smoke anywhere.. just at start up, first time in the morning. Starts pretty easy cold, starts real easy warm..
