Shutting down the engine
jpekarek
10
Vancouver, WA.
When I bought my 5 ton, the engine shut-off handle had been disconnected at the engine side. (the distrubutor I guess). So everytime I drive it I have to dump the clutch in 5th gear to shut it off. This raises somequestions.
1) Is this hurting my clutch or engine?
2) Is there a common reason why someone would disconnect this mechanisim?
James.
area52
San Bernardino CA
I would think that its not too good for your engine.
Why not just hook up a new cable/handle to the stop lever on the IP? Go get a cheap bike cable and hook it up.
M543A2
11
Warsaw, Indiana
We replaced a broken cable with a heavy duty pull cable like is used on chokes on older engines. If you want to stay original, order a new shut-off cable from Saturn or other supplier.
It is not good to keep killing it with the clutch.
Regards Marti
Floridianson
2,498
Interlachen Fl.
#1 Fix emergency shut down. (fuel cut off)
#2 Fix electric shut down. ( fuel cut off )
#3 Shut it down using thumb screw on the side of electric fuel cutoff. ( if you don't fix elect. cut off )
#4 Don't kill motor with clutch PLEASE.
#4 Answer to questions. #1 yes #2 no
zout
154
Columbus Georgia
Take your left hand and stick out your pointer finger
Take your right hand and grasp it around your left hand pointer finger tightly
Twist the living crap outta your pointer finger hard.
Inside the transmission is your mainshaft - when you dump the clutch and being in any gear is placing this load on the mainshaft twisting it - it can only take so much twist. Seeing as your brakes are applied - truck is going nowhere as well - something has to take the "load". Something will eventually break - OR put in an incubation stage as it will eventually break.
Easier to repair the original problem.
Hammer
396
Winlock, WA
He has a multifuel 5 ton. Or at least I am guessing by his avatar.
So it has the same normal shutdown like the deuce.
And you can use a LOT of things to work as a shutdown.
Just think of the time you NEED to shut it down, and can't do the 5th gear dump?
