Side Rear View Mirror Grommets
firefox
General
51
Berkeley CA
Found this substitute for the gromet and it seems to fit reasonably well. from McMaster-carr
You may be able to get them cheaper elsewhere, but at least you have the specs here. It is not an exact match but I could not finf an exact match out on the web,
9600K96SBR Rubber Push-In Grommet for 7/8" ID and 1/16" Material Thickness, 3/4" ID, Packs of 10
1Pack
1 0 12.29Per Pack 12.29
Note: This is not a perfect fit, but reasonable.
You need to be careful when sliding the cover on
the arm or it will make the grommet pop out.
I suggest a little lube just on the grommet.
