Side Rear View Mirror?
m38inmaine
101
Maine USA
I'm not sure how to remove it but I had a mirror fall off and by a miracle it did not break. It was held on by a clear silicone adhesive. You may be able to pry gently with a non marring tool while heating the face of the mirror with a heat gun.
cucvrus
10,507
Jonestown Pennsylvania
I remove them GM mirrors from the stainless steel mirror heads with a propane torch and the glass falls off. Be gentle and don't over heat. Good Luck. I even used the ones that said objects are closer then they appear. Why because I had them. Not sure if they still do that. If they do I am so used to seeing and using them I don't even notice.
firefox
General
1,844
52
Berkeley CA
Just to make sure I understand, we are talking about the mirrors that are mounted to the side of the doors and not the one that is glued to the middle of the windshield, right?
