Significant Fuel Leak M998
H1NSX
Oklahoma
Hello guys. I have a 1990 M998.
It is leaking fuel directly into the air-filter canister. Fuel is also coming out of the air-filter barrel and running down the passenger fender.
All I can find is a hard plastic line coming from the engine into the top side of the air-filter barrel. Also I can see a rubber house directly between the barrel and air stack housing.
I can send photos if need be.
Please help. Thanks in advance.
H1NSX
Oklahoma
That has crossed my mind, I will have to check. Not sure yet how I would be able to tell if the diaphram were bad.
Thanks for your prompt reply to inquiry
NDT
6,346
Camp Wood/LC, TX
No kit, replace the entire thing. If the pump is the culprit, you need to check all the gear cases for being full of diesel as well, the vent system is tied together with the air cleaner being the high spot.
H1NSX
Oklahoma
I have now learned from the prior owner the fuel pump is new. It certainly looks new too.
Any other advice based on the info stated in the original post?
I plan to post photos of the leak soon.
Thanks for your advice so far NDT.
NDT
6,346
Camp Wood/LC, TX
There is also a vent line that comes from the fuel tank to a little filter right on top of the air cleaner. I have never seen this, but I suppose if you overfilled the tank and parked on a down slope, maybe it could run out?
Action
1,557
East Tennessee
You would almost need to be on the nose. That vent is at the bottom of the winshield.
NDT
6,346
Camp Wood/LC, TX
Something else crossed my mind. Are you SURE the fluid it diesel? If it's ATF you could have vampire disorder.
Wire Fox
161
Indianapolis, Indiana
This. A whole lot of this. It really behaves like the "vampire" where fluid gets pressed up through the vent lines and floods every connected item with ATF.
Otherwise, remember that new parts can be just as bad as old parts. It's not unheard of or even rare that a "brand new" part is DOA.
H1NSX
Oklahoma
Thanks for the new leads guys. I will be investigating those ideas in the days ahead. I will post a picture or two soon to show what I see.
