Is it necessary to periodically replace the silicone brake fluid (DOT5) in these trucks? I have not replaced mine since I bought the truck more than a decade ago. I always replace regular DOT 3 and DOT 4 brake fluids on my cars, trucks, and motorcycles every two years because it is hygroscopic (absorbs water) and causes corrosion in the brake system. DOT 5 silicone fluid is not hygroscopic. Does it deteriorate with age?
Do you need to remove the vent line on top of the master cylinder to remove the lid itself to add brake fluid if you choose to bleed to brakes and replace the fluid?
