SasquatchSanta
- 18
- 0
- Northern Minnesota
In a previous post I mentioned a sticker on one of the fuel filter canisters on my new LDS engine stating that the fuel density compensator had been by-passed.
The sticker was obviously in error because upon close inspection I found the FDC to be configured the same as in Fig. 1 below.
I don't want to by-pass the fuel density compensator but I would like to simplify the plumbing by eliminate the two fuel line loops.
"Evidently" the reason for the two fuel line loops, one on the back and one on the block side of the pump are to allow a convenient means of bypassing the FDC.
If this is the case why can't the two fuel line loops be eliminated by removing the lines and plugging the holes? See the attached picture of the back of my pump with the rear loop removed and the hole plugged.
Am I missing something here??? Will removing the loops effect the operation of the pump?
To my way of thinking, if the fuel line loops aren't needed, eliminating them would eliminate a possible source for future leaks.
