Aight folks, well hopefully I won't have 500,003,043 posts before the actual finish product is complete but I thought I would go ahead and show my next project since this will be a pull out and overhaul more than likely. ODO in the 915A1 says 133,000. Was a Kansas National Guard truck. At that mileage the big cam could be just getting broke in. Tried a test run. Injection pump is puking from the bottom of it. Going to see what is leaking hopefully tomorrow. Engine sounds like it has good compression.
Big Cam III rated at 400hp/1350ft/lbs. At the current moment it has an Untagged Schwitzer turbo on it. I am going to assume it is a 4LHR. I am going to plan on some upper range injectors. some pump work. HT4B Holset turbo and dual fuel line mod. Should see some pretty respectable numbers out of it.
I plan on using the front mount cross member from the 915 in my truck. Being that it is 33 inches across on it with the support plates behind it at 33 3/4" across should fit just fine so that will save up a lot of the front mount fab time that some folks have said is a problem. The rear mounts are already set up from the CAT transmission install. Everything else should be pretty easy going compared to my last project.
This truck sat in south texas for a few years so it was covered in barbs. Bad enough that my crowbar cant break thru them.
https://www.youtube.com/watch?v=cUpSJUBt6rs
