single and dual cylinder compressors
lawdog1623
Texas
Does anyone have experience with dual cylinder compressors? I think my 109 has a dual but the 35a2 has a single cylinder. I have yet to try to run tools off of the air system. Am i correct in assuming that the dual cylinder is better as far as output? I figured it wouldnt be noticeable until you try to run air tools. Does anyone have opinions on this? I have found a dual cylinder conpressor that is near me and very cheap but i already have a new single cylinder spare. I dont want to waste the money if this isnt an upgrade.
VPed
289
Clint, TX
I do not know what the cfm ratings are but I replaced a failed dual with a new single and I cannot tell the difference in operation between the two. Takes about the same time to go from zero to full pressure with either.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
There is not much difference in the two. I feel the single in my deuce pushes a tad more air than the dual in my wrecker. I know the dual piston is rated at 7.5 cfm.
gimpyrobb
27,785
749
Cincy Ohio
Ray, that doesn't matter to me. I learned it a long time ago and forgot! It isn't anywhere near my 18cfm shop compressor, so it is slow as tar.
