RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Howdy folks, wishing everyone a great week ahead! I had a question about my latest project to my M1009 and some advice or tips would be greatly appreciated. I am installing a single DIN radio (made a center console for it, may post pics once its all done) and I will be using 4 speakers with subwoofers in the rear with an amplifier. Here is what I have to figure out. If I use power from the one of the batteries grounded to the body/frame would I be able to just get 12V? Also, what are some good ground spots in the rear (maybe the bus bar?)? Also, anyone know anywhere in the fuse panel that turns on when the key is on in the accessory location that I can use as the signal wire for the radio to turn on when the truck is on? I want to try to avoid going into the steering column for a singal wire since I do not have a lot of time to complete the project. And advice would be greatly appreciated. Also if you have pictures of what you did that would be amazing! Thanks everyone!! Happy fixing!
