single tires
MoAllen
Jefferson City MO
Hello all,
I know it is here somewhere but can not find it about running single tires . I remembers something about reversing the hubs what is that and how is it done Please.
Allen Lost in Mo
DanMartin
Hillsboro, Oregon (USA)
Here's a few good things to read:
http://imageevent.com/cranetruck/m35dualstosinglesconversion
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&p=280700
There's others...but that'll get you started.
Note that if you just want to singe out the deuce with stock tires, hub flipping is the way to do it. If you want to go bigger tires like on the A3s, you can get away with not flipping the hubs by buying the correct wheels from ODIron for the bigger tires. I have this configuration and did not need to flip the hubs because the ODIron wheels are spaced correctly.
It's a simple operation to flip the hubs if you need to do it.
OPCOM
27
Dallas, Texas
I still want a set of the OD Iron wheels. It would put me just under 13FT, which is the low bridge llimit.. Also give me much better RPM ease on the highways.
devilman96
17
Boca Raton, FL
Patrick,
You should bring that rig of yours to the florida rally in February and we will put some new shoes on her for you!!!
Not to mention I owe you for a lot of electronic advise!
