Slave cable??
dm22630
42
Front Royal, VA 22630
Where do I get a slave cable for a deuce?
Can I plug it in a deuce with NO batteries & start the dead deuce via a running deuce?
How long is the cable?
Are there different plugs for slave cables? (nato, etc) Some of my deuces have a newer looking plug than the old types I was used to seeing.
1,331
decatur alabama
there is the single and double pole plugs. I got a slave cable from Emmando on here. ITs i believe 20' and is a large heavy duty one. good price shipped.
get one slave cable and 2 adapters and you can start anything.
sermis
17
Temple, TX
There are 10' 20' 50' cables. 50' are about 70+ lbs. there is single pin nato and 2 pin. depends on what you want.
jimm1009
71
Louisville, KY
Makes srue that your battery cables are insulated so they will not short out against the frame or any other metal objects or to each other.
Otherwise you will be welding whether you want to or not.
Jim
