Slave kit curios ? on M923
firefox
General
1,844
51
Berkeley CA
I just got a slave kit off an M923. Acording to the TM
there is a gasket and a plastic form that fits over the
NATO slave casting. So you grab the casting with wires
attached, thread it thru the gasket, then the pastic form,
then thru the bulkhead, and finally thru a piece of sheet metal with bonded nuts on it and a sheet metal cowel to protect the cables. Then you insert the four screws thru the flange on the casting and the aforementioned parts and thread it
into the captive nuts on the sheet metal gizmo.
Clear so far, I hope. My question concerns two things.
The first is, does the cutout on the bulkhead have the same matching keyhole shaped cutout that is on
the sheet metal gizmo with the captive nuts?
The second is, are the size of the holes punched in the bulkhead oversized to accomodate the tits on the
plastic form and are the holes dimpled or tapered in any way to acomodate the tits on that plastic form.
The reason for these questions is that I am adopting the connector to a different vehicle and have to make the appropriate cutouts in the bulkhead.
Thanks for any info on this strange question.
firefox
General
1,844
51
Berkeley CA
I'll see what I can do, but I'm thinking that if you need pics, you wont have seen the
bulkhead in question with the slave kit removed. Who knows though, you guys are real
magicians when it comes to this stuff. Thanks!
firefox
General
1,844
51
Berkeley CA
I answered my first question myself. It is just a round hole in the bulkhead, not a keyhole.
I am attaching a photo. The tits I am refering to can be seen on the plastic form right at the point where the screw exits the form. My guess is that the holes for the screws in the bulkhead
are the size of the tits at there base so that they pass thru the bulkhead.
The bulkhead would be between the form and the two pieces to the left of the assembly.
Thanks for your comments.
Bruce
