Slip joint orientation
cranetruck
75
Meadows of Dan, Virginia
According to the TM, the slip joint is to be installed "forward" when mounting the drive shafts. After a casual search (google also), nothing pops up to explain this, so why is it important?
I assume "forward" means towards the front of the vehicle and may have something to do with exposure of the seal to dirt and debris perhaps?
cranetruck
75
Re: RE: Slip joint orientation
sermis said:
I think to let water drain out?
They are not all tilted down....
From the 2320-260-20 TM page 2-240, the slip yoke is always at the "power input end", so the drive shaft shown in the image from the transfer to the 2nd axle is not installed correctly.
dlawbrey
Boyce,La.
On the 5 ton it allows the shaft to clear the trans at the point where a pto would be installed on the drivers side of the tranny.We had a truck that had it installed with slip joint to the frontand it peeled the heads off of the bolts holding the cover on the tranny. This is for the front drive shaft.
