Corvette1974
- 1
- 18
- Upper Black Eddy, PA
Hello,
Quick question - After swapping to my NV4500 (over a year ago now) I did notice that the driveshaft was slightly (maybe 1/4 to 1/2 inch) less engaged into the transfer case. I feel it is now engaged too little, and I think it is starting to wear on the output shaft bushing (there seem to be a slightly larger leak and play in the shaft now). Any thoughts on how much engagement there needs to be, maybe with measurements from stock trucks?
If my shaft ends up being too far out, what are my solutions? Should I get an extended sip yoke if available and swap that over, get a new driveshaft made, slip yoke eliminator, etc? Let me know what you guys think.
Once I have this info, I will finally make my NV4500 swap thread. I have waited this long to confirm long term function.
-Will
-Will
